The Verified+ badge represents the highest quality standard on the PrestaShop Marketplace. It assures merchants that a module has passed comprehensive validation checks and meets PrestaShop’s most stringent technical reliability criteria for versions 1.7.8 and above.
⚠️ The Verified+ badge does not apply to PrestaShop versions below 1.7.8.
What “Verified+” means
For merchants
A Verified+ module guarantees:
Technical reliability: works flawlessly across environments
Security assurance: zero known vulnerabilities
Future compatibility: always compatible with the latest PrestaShop versions (from 1.7.8)
Safe operation: adheres to a strict override policy
For developers
Achieving Verified+ means:
Quality recognition: official PrestaShop endorsement of technical excellence
Competitive advantage: stands out from standard modules
Enhanced visibility: featured more prominently in search results
Verified+ Requirements
To receive the Verified+ badge, a module must meet all of the following criteria:
| Requirement | Description |
| Clean Validator Scan | No automatic decline issues detected by the PrestaShop Validator |
| Security Compliance | No known vulnerabilities |
| Minimal Overrides | Only technically unavoidable overrides permitted |
| PHP Compatibility | Error-free execution on recommended PHP versions (for all compatible versions from 1.7.8 and up) |
| Version Compatibility | Works with the two latest major PrestaShop versions (8.x and 9.x) |
| No Debug Errors | No Debug Mode issues across compatible PrestaShop versions |
When and how you receive the Verified+ badge
You don’t need to apply for the badge, it’s assigned automatically by the PrestaShop Validation team during the standard validation process.
If your submission meets all Verified+ requirements, your module receives the badge automatically.
⚠️ If a later update fails to meet all criteria, the Verified+ badge will be removed automatically.
